Re sx10
profoundwill
RE SX10
Old Made in the USA Version
Dual 2 ohm
Works Great, Looks Great
$160 obo
Free Shipping
SX10-D2 (SX.10.D2/SX10D2) Features:
* Dual Composite 2-piece Cone
* Rubbertek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3 ” 8-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Triple Stack Magnets
* Progressive Spiders
* Wrap around Rubber Gasket
SX10-D2 (SX.10.D2/SX10D2) Dimensions:
* SX10 10" Dual 2ohm Subwoofer
* Mounting Depth - 6”
* Mounting Hole Diameter - 9.25”
* Overall Diameter - 11”
* Bolt Hole Circle - 10.125”
* Motor Width - 6.5”
* Motor Depth - 3.25”
* Basket Depth - 2.75”
* Displacement - 0.15 cu. ft.
* Weight - 23 lbs.
SX10-D2 (SX.10.D2/SX10D2) T/S Parameters:
* Electrical Q Value -Qes: 0.29
* Mechanical Q Value -Qms: 4.3
* Total Speaker Q Value -Qts: 0.27
* Free Air Resonance -Fs: 30.7 Hz
* Equivalent Compliance -Vas: 21.8 liters
* One-Way, Linear Excursion -Xmax: 22 mm
* Efficiency -SPL 1W/1m: 85.2 dB SPL
* Effective Piston Area -Sd: 310 cm^2
* DC Resistance -Re: 1.9 ohm
* Nominal Impedance -Znom: Dual 2 ohm
* Thermal Power Handling -Pe: 1000 W
* Force Factor -Bl: 21
SX10-D2 (SX.10.D2/SX10D2) Recommended Enclosures:
* Ported Compact: 1.0cf tuned @ 35Hz
* Ported Optimal: 1.25cf tuned @ 34Hz
More info here RE Audio SX Series SX10-D2 10" Dual 2ohm Subwoofer
profoundwill
profoundwill
Birmingham, AL
outsideshot23
