Sold Re Sub
djarmy2004
djarmy2004
I have 1 15" Re Audio SRx Sub. Asking 120 Shipped OBO. This sub is BNIB only been opened to take pics.
http://s101.photobucket.com/albums/m67/married2asoldier/?action=view&current=DSCN2539.png
http://s101.photobucket.com/albums/m67/married2asoldier/?action=view&current=DSCN2538.png
Specs are as follows
Engineered with new magnet covers that aid in cooling the voice coils while protecting the magnet
Flat wound voice coils
Kraft Pulp Cone
Rubatek Foam Surround
Pressed Steel Basket
4-layer Copper Voice Coil• FEA Optimized Motor Structure
Double Stack Magnets
Linear Spiders
Foam Gasket
Mounting Depth - 6.75"
Mounting Hole Diameter - 13.75"
Overall Diameter - 15.5"
Bolt Hole Circle - 14.75"
Motor Width - 6.25"
Motor Depth - 2.5"
Basket Depth - 4.25"
Displacement - 0.16 cu. ft.
Weight - 17.5 lbs
QES: 0.45
QMS: 4.87
QTS: .41
Free air Resonance - FS - 23 HZ
VAS: 203 Liters
XMAX: 18 MM
SPL @ 1W / 1M: 87.6 dB SPL
Effective piston area: Sd: 810 cm ^2
Dc Resistance: RE: 1.8 ohm
Nominal Impedance: Dual 4 Ohm
300w RMS Rated
600 watts max
Force Factor, BI: 14.35
djarmy2004
djarmy2004
djarmy2004
Hopkinsville, KY
djarmy2004
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
