Sold re se15 and orion 1200d amp
khmer86
up for sale is one re se15 dual 4 and orion 1200d amp.
re se15 for $100+ ship orion amp for $175+ ship or best offer. pm if ur interested and ill have pics.
specs for re se15...
600W RMS
Dual 4 Ohms
Mounting Depth: 7.75”
Electrical Q Value -Qes: 0.55
Mechanical Q Value -Qms: 4.3
Total Speaker Q Value -Qts: 0.49
Free Air Resonance -Fs: 22 Hz
Equivalent Compliance -Vas: 209 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 88 dB SPL
Effective Piston Area -Sd: 810 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 600 W
specs for the orion amp....
1200W Class D Mono Amplifier
RMS @ 4 Ohm: 1 x 250
RMS @ 2 Ohm: 1 x 400
RMS @ 1 Ohm: 1 x 600
Variable low-pass 30Hz to 250Hz
variable high-pass with INTELLi Q 20Hz to 150Hz
10dB of boost with INTELLi Q
Remote gain capable
Selectable AUX out
Fuse size: (2) 40 ATC
Dimensions: 11" x 10.2" x 2.4"
dont mean to post dump in the least bit, But thats a D1200, not 1200D. Its only 600 RMS @ 1 ohm, Instead of the 1200RMS that the 1200D is at 1 ohm.
If the SE was a D2, thatd be one helluva set-up.
Either way, Bump for nice equipment.
khmer86
khmer86
memphis, TN
revrider1
