Re Se, Tc9
bushtree
What do you think would perform better in a 1 cu ft sealed box?
a 12" RE SE or a 12" TC Sounds TC9
The SE is about $45 more than the TC9
SE T/S
Electrical Q Value -Qes: 0.49
Mechanical Q Value -Qms: 4.5
Total Speaker Q Value -Qts: 0.44
Free Air Resonance -Fs: 25.1 Hz
Equivalent Compliance -Vas: 72.9 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 86.1 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
TC T/S
Qts 0.354
Qes 0.384
Qms 4.46
Fs 27hz
Res 5.96Ω
Ls 4.35mH
Lp 8.26mH
Rp 10.88Ω
Dia 250mm
Vas 35.3l
mms 331g
cms 104um/N
bl 29.2T*m
Spl 84.7dB
Xmas 18mm
RMS 800w
I have 800watts to work with..
I like my old SE. Back when they had the eyeball cap. I haven't heard the new ones.
But I also like my tc9 woofer. I think either choice would be a good one.
According the manufacturer box specs the SE is best in a 1 cube. The tc9 in a 1.4 cube.
Alright guys, thanks.. I was just asking, because i am going SEALED, and i've heard that the TC9 is better then ported (Dunno if thats even true, just what ive heard) so i wasnt sure.
bushtree
bushtree
San Diego
Sunfire01
