Sold RD5750.1 for Sale
hittin1
My life is turned upside down.
1. Product:
RD Audio5750.1
2. Specs:
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Heavy duty cooper layer double sided epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24 dB low pass (LPF) crossover variable
18 dB bass boost equalization control variable
180 degree variable adjustable phase shift
24 dB subsonic filter variable
Selectable Switch for MASTER and SLAVE Operation
Speaker short, over current, thermal, and DC protection circuit
RCA line input and line output
2 x 0 gauge (AWG) battery input connectors
Efficiency: 86% at 4 ohm, 100 Hz
Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
Operating voltage: DC 10V ~ 18V power input
Damping factor: better 350 into 1 ohm
Wired remote controller
MSRP
$2199.00
Specifications
RMS power, 2 ohm linkable/dual mono 9000w x 1ch
RMS power, 1 ohm mono 5500w x 1ch
RMS power, 2 ohm mono 3200w x 1ch
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500A(external type fuse - not included)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 222(W) x 52(H) x 620(L)mm
3. Description/Condition:
I bought this amp from Steve Miller used. The heatsink has some scratches on it. It was like this when I bought it, and it doesn't effect the amp in any way.. I had to rethread 2 of the speakerwire inputs do to previous owner , but they work just fine. The heatsink is from the 1st line of rd5750's which used to be called rd5000.1D. They are the same amp. I had it repaired about a year ago and have since run it strapped with another 5750.1 with no problems.. If you keep this amp supplied with plenty of current, you should have no problem running it well below 1 ohm.. I ran it a .5 ohm daily, with a DC Power alt and 7 batteries.
cosmetic-7
preformance-10
4. Price: :
$775.00 shipped lower 48 , insured, (PP fee's included as well.)
$800 shipped
with stinger digital voltmeter AND 1- 0/1 ga.in 2- 0/1 ga out (dual fused 300amp each included) distro block for external fusing of both power supplies
View attachment 26521008View attachment 26521007View attachment 26521006View attachment 26521009View attachment 26521010
also selling 2-15" Rd HW's v.2 in great condition
3 SVR drycell batts. call me for more info.
I have plenty of Refs.
337-438-2957 cell
hittin1@hotmail.com
YouTube - hittinone's Channel
help cover the cost of a funeral.. I still have plans for more power in the future. lol
If you hear of anyone wanting my HW's, send em my way.. I'll post em when I get the time to pull them out of my ride and from the enclosure. later Twiz
Oh man that is terrible. Ill keep my ears open for you.
very close until you start putting 16-18 volt to them then the d9 really comes alive. d9 also better when strapping at .25 ohm with high current.. I would take either amp on a 12 volt set-up. they are solid and dependable so long as you have proper electrical.
hittin1
hittin1
Lake Charles, La.
hittin1
