rca next to power
not sure if this works for RCA's but go to radioshack and buy some 2" ferrite doughnuts(basicly a doughnut shaped magnet.) wrap the RCA cables around the magnet a few times in three places. usually the center of the run, and each end. ive used this a few times and it reduced EMF noise introduced into speakers. BUT this was in a Home environment.
Matt
mat3833, I'm not too familiar with that, but from what I know, shouldnt those be wrapped around the offending equipment rather than the one experiencing problems?
keep_hope_alive, I kind of suspected that, but I've seen many posts and articles where people say these and speaker wires should be kept away from power lines otherwise noise would be introduced. RCA more so. This isnt true?
You will hear varied reports of folks who have experienced noise issues that went away when they separated the power and RCA cables, but most of us contend that the problem was elsewhere and the results are coincidence. I have run power and RCAs together and never had an issue.
BTW the field strength of a raditated noise signal decreases with the square of the distance, which means that even a small separation makes a difference in how much noise can be picked up. So if you're concerned, just don't tie wrap them together.
I've ran on the same side in quite a few cars with no issue when it was a pita to take the other half of the car apart. No issues at all for me using cheap RCAs and some Walmart kits. But when possible I try to run on desperate sides.
TDot
TDot
Bronx
Sub Woofin
