RCA cable help
  • 2
AJM511
Chill as a Cucumber
My friend tried to install my old system in his truck, but he didn't have any RCA's so he dug up some old av cables to use instead. We got the amp all setup and turning on, but the sub barely moves. I tried turning up the gain but It has to be almost all the way up to get it even close to what it was before. W'ere using the same wires that I used, same sub, same box, same amp. I'm almost sure he needs to buy some ACTUAL RCA's but I'm not sure.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
781
It's really hard, almost impossible to induct noise into RCAs. All you need is a simple set of shielded RCAs. Some home audio guys once did a...
19
Yep, the subs don't move at all when both RCA cables are plugged in. I updated the firmware this morning. Unfortunately it didn't fix my issue...
33
6K
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
781
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
671
AJM511
Chill as a Cucumber
AJM511
groveland, ca
Kangaroux
    May 24, 2024
    May 23, 2024
