PPI PAR-245 EQ
5 Band Parametric Equalizer
Preamp Line Driver - 10vrms
Choice of 16 Selectable Frequency/Q Settings for Each Band
Front and Rear Outputs with Fader Control
Dual Selectable Illumination (green/red)
Center-Detented Boost/Cut Controls
±15 dB Boost/Cut for Each Band
Defeat Switch
Gold-plated RCA Input and Output Connectors
PWM (Pulse Width Modulated) Power Supply
Independent L & R Input Gain Adjustments
Input Clip Indicator
Designed and Handcrafted in the U.S.A.
Signal-to-Noise Ratio 110 dB
Total Harmonic Distortion (1 kHz, 1 VRMS) 0.002%
Boost/Cut Range ±15 dB
Equalizer Center Frequencies and Q Values:
Band - Frequency - Q Value
Sub (30 - 66 Hz) 2.0 - 3.0
Low (90 - 300 Hz) 3.0 - 5.5
Low-Mid (430 - 900 Hz) 2.5 - 4.5
High-Mid (950 Hz - 4.6 kHz) 2.5 - 6.0
Treble (6 - 16 kHz) 1.3 - 3.3
Maximum Input Voltage (Flat) 10 VRMS
Maximum Output (10 kW Load) 10 VRMS
Frequency Response 3 to 100 kHz
Supply Voltage 9 - 15 VDC
Dimensions 4.60"L 6.75"W 0.95"H
Old school PPI, some of the best build quality you'll ever find in an eq....Arguably the best parametric EQ ever built.... Definitly the cleanest sounding and best quality eq i've ever used. I have a par-245 in my car and it's the bomb diggity.
Manual:
http://www.precisionpower.com/Manuals/Accessory%20Manuals/Precision_Power_PAR245%20Equalizer.pdf
Near mint....there's a tiny scuff on two of the very very corners (front right and back right)...otherwise it's flawless, warranty seal intact. This one is in even nicer conditon than the one in my car right now. I was originally going to install this one in my car and sell the other more scuffed one, but im lazy and have too much on my plate with other stereo needs, so the old one is staying and the fancy minty one is up for sale.
PRICE DROPPED:
$150 +ship firm
These get more and more rare every year. ESPECIALLY minty like this one
No Trades
USPS INSURED
username/date for caco
Ref's: Years of selling here. You're in good hands.
PM me with offers or any questions.
PPI PAR-245 EQ
Defeat Switch
Manual:
PRICE DROPPED:
$150 +ship firm
No Trades
USPS INSURED
