Rainbow SLC v. SLC Kick
beckSHO
Well, I've narrowed down my speaker choices down to the Rainbow SLC 265, and the SLC 265 Kick. The reason I can't decide between the two is... I don't know the difference. The SLC Kick is about $60 more than the SLC. So, I'm wondering, what really is the difference? Is it audible? Or does it have to do with the build of the speaker? Which one would you chose, and why? Hopefully you guys can help me out. Thanks.
Basically the kick bass component sets have kick bass loudspeakers that are designed to play from 80-180Hz. The kick sets allow the subwoofer(s) handle 80Hz and below so that they can focus on the 80-180Hz range with increased output and clarity. They are also designed for use in semi-enclosed installations (doors).
It is absolutely essential that the kick bass component sets be high-passed at 80Hz. If they are allowed to play down to the 50-60Hz range the spiders will be damaged.
Hopefully that helps.
Thanks Audio Junkies. That does help. I think I might pick up the slc Kick for x-mas because, I already have my subs which I can set lowpassed to 80hz. I'll also pick up a nice new amp for the speakers. Is it fine to use the highpass on the speaker amp, or should you buy a crossover unit?
beckSHO
beckSHO
Michigan
Freestyler717
