Radio Shack gold plated terminals...
Big Dee
... **** big time.
They are a little pricey and the build quality is horrible.
Both negative push springs came loose and didn't hold the wire in anymore.
I sealed them up with silicon caulk since they let a little air through and drilled some holes in the back of the box, much better solution imo and costs nothing.
I've always used the Radio Shack screw down rectangular terminals and they're great. They're only about $3.00 and worth it to me. I've never had them leak and they are really useful when you have to move your enclosure a lot or switch voice coil configs a lot.
do NOT get this termial:
http://www.radioshack.com/product/index.jsp?productId=2103795
or the stereo version of it. they didn't even attempt to make it airtight, and i couldn't even get it close to being sealed using weather stipping. i ended up sealing the holes with silicone and usnig the nuts and bolts method.
if you must get terminals go for on of these:
http://www.radioshack.com/product/index.jsp?productId=2102834
http://www.radioshack.com/product/index.jsp?productId=2103794
but they're quite big and cost a lot compared to parts express //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I will never use spring loaded terminals ever again. I have tried them in the past and they have always given me problems. The only terminals I would buy from parts express would be these:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-311
But even then, they would not be any better than what I use from radio shack with the ones I buy locally being cheaper because I save on shipping. Mine have never leaked and are very sturdy.
I just finished my most recent box and used the bolt and washer terminal, best idea IMO.
Same here...Ill never go with terminals again...the partsexpress ones were good but they were pricey once you added the stupid shipping. The one I got from a local audio shop leaked like hell...
I have hundreds of bolts and nuts here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Anyone just drill holes in the box to run wire through???? Thats all I do.
I used to but I move my subs around too much now and switch voice coil configs quite a bit as well. Having wires at random really stresses me out. I would much rather use a terminal per coil to keep things open.
I have thought about the bolt and washer method but I have a feeling it would get on my nerves.
Big Dee
Big Dee
Ohio
Big Dee
