"Laughing Gas"
Ya it can be done. Nitrous Oxide is already mixed with oxygen hence the Oxide. But pure 02 oxygen can get you fucked up as well, thats what they use in airplanes to make you calm and euphoric
First, NO2 is inert. You can spray it on an open flame, and it won't do a thing. Only if you have rather high temperatures and pressures will it become flammable because the chemical bond between the nitrogen and the oxygen breaks such as when NO2 is used in a car engine. The pure oxygen helps the fuel burn faster and more completely while the nitrogen is inert and helps with cooling.
To pump pure oxygen into an airline cabin or to even put it on a plane would be a huge fire risk. Not only would you have the thousands of gallons of flammable airplane fuel, but you would be adding an accelerant to it which could turn a small cabin fire into the Hindenburg. The oxygen content in the cabin is the same as when you are on the ground i.e. 21%. (http://www.rtmagazine.com/Articles.ASP?articleid=R0408F02)
When I was 17 a buddy and I purchased a 5ft Nitrous tank(medical grade).We made a couple grand selling baloons at parties and so forth. Good times //content.invisioncic.com/y282845/emoticons/smokin.gif.f1dc8d2acb1809e863ebd6a47eaa0d45.gif
yeah when i was at bonnaroo, people had tanks of NO2 and was selling balloons for 5 bucks a pop. I said screw that and bought some rolls
i heard a buddy of mine went to a party one time and they had a tank of that sort, dont no if it was n02. they were taking hits off of the tank and he said that the thing was so cold they lips were bleeding from putting they lips on it when they were getting all messed up.
if you want to try it you can get the little canisters of it at any restaurant supply store as it is used to produce restaurants own "homeade" whipped cream and then any local head shop will sell crackers with pins inside just load the cartridge in stick a balloon on top of the cracker give it a small twist and then inhale and your set. big thing about it in the local paper not to long ago here
They should not have been putting there lips on the tank //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif They should ave been filling up balloons //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Nitrogen = flammable
Nitrous Oxide (no2, as in "NOS") = accelerant
Nitrous Oxide (n2o, laughing gas ) = will put you to sleep
"Whippets" (like co2 canisters) = Hippie crack.
It's stupid to huff anything,
And it's insane to huff anything **in your car.**
Did you know 'flammable' and 'inflammable' are the same thing? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I used to work at a headshop supplier's warehouse - the lackeys in the back were assigned to dispose of some several thousand canisters of nitrous (whippets) - they were variously flavored, and had expired;
So twenty buffoons went out back with a box of 'crackers' and let off a shit-ton of these whippets. Whole place smelled like rotten bananas and strawberries.
I think the entire block was lightheaded //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Anyway, don't fuck with it. It's stupid shit, for 15 year old stoners who don't have enough allowance to buy weed. You'll die.
monte_carlo97
Power Acoustik Punk
monte_carlo97
Central Ohio
Kali77
