"Broken" RE Audio XT1600.2v3 (Pops fuses)
porksoda
Broken RE Audio XT1600.2v3 (Pops fuses)
* XT V3 Series 2-Channel Class DE Car Amplifier
* RMS Power Rating:
o 4 ohms: 250 watts x 2 chan.
o 2 ohms: 500 watts x 2 chan.
o Bridged, 4 ohms: 1000 watts x 1 chan.
* Dynamic (Max) power output: 2000 watts
* High speed digital stereo amplifier
* Elevated Efficiency Platform guarantees the abundance of power, without a heavy drain on the vehicles charging system
* Remote bass level input (remote level control sold separately)
* Pulse Width Modulated MOSFET power supply
* LED power (green) and protect (red) indicators
* Variable Bass Boost (0 to +12 dB bass boost at 45 Hz)
* Screw terminal barrier strip speaker connector accepts 8-18 AWG speaker wire
* Soft start turn-on technology
* 2/1 channel operation
* 1 RCA Pair of preamp RCA outputs to daisy chain multiple amps
* 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
* Heavy duty aluminum alloy heatsink for excellent heat dissipation
* Convention cooling system
* Nickel-plated RCA level inputs
* Nickel-plated screw terminals
* Maximum Input Signal: 6V
* Low level input sensitivity: 200mV to 8V
* Fully adjustable butterworth high and low pass crossover filters
* Variable high-pass filter (40-1,000 Hz, 12 dB/octave)
* Variable low-pass filter (40-250 Hz, 24 dB/octave)
* Subsonic filter (15-40 Hz, 24 dB/octave)
* Average Efficiency:
o 4 ohms: 70%
o 2 ohms: 65%
* Signal-to-Noise Ratio: 110 dB
* Frequency response: 5-50,000 Hz
* Dimensions: 14-1/2"L x 10"W x 1-7/8"H
I am unsure on how much this is work so how about $50 shipped or trade (Just let me know what you have to offer)
porksoda
porksoda
USA
porksoda
