Sold quickstart 200 amp cs-144 alternator
Naxis2k1
grade A whiteboy
yo guys got this awsome alternator for sale, it is a New Delco-Remy CS-144 type, 200 Amp Dual Rectifer with new OEM Voltage Regulator.
Suggested Retail $549.95
http://www.alternatorparts.com/Extreme%20Duty%20Dual%20Rectifier%20CS-144%20type.htm
theres a link to check it out
i bought it brand new, payed 380 for it after shipping. and modified it to bolt on to any 4.3 aplications by machining down the 9-oclock mounting hole so its a thick as the stock 105amp alt. i never got the chance to use this great alt because my van broke down before i could use it, so time to sell it. this alternator can be used on nemerous car, hes a link to see how.
http://www.alternatorparts.com/Alternator_brackets_1.htm
iam not looking at get all i payed for it doo to the fact that i did modify one mounting hole, but should still work on all the same aplications with some washers in place.
asking 255 shipped to anywhere in the US.
more of couse for canada (no over seas)
i will post pics later on today to show the modification..
if i remember corectly the idel amps at 600-800 rpm is 90-100.
not for sure tho you could always email quickstart and ask they sould be able to tell you for sure. just give them a rpm number and iam sure they will give you a answer great people to deal with. and as for it fitting your car all i could say is look at the alternator and see if its got a 6-oclock and 9-oclock mounting holes if so then it should drop in no problem(might need a longer belt to comidate size tho)
NOTICE THE POSITION OF THE MOUNTING HOLES
will it fit a 2002 vw golf 2.0L?
to answer your question......i dont know:rolleyes:
what i would do if you are intrested in buying this alternator and wondering if it fits your aplication email http://www.quickstartalternators.com and tell them your problem, they should be able to tell you if you need a mounting kit (witch they sell). or if it will bolt right in place.
This Alt Needs To Go Will Sell For $175 Plus Shippingas Low As I Can Go. Need The Cash For My New Car. Thats A 200 Hundred Dollar Savings From A New One.
Pm If Your Intrested.
and might i add a ****ing steel at this price!
hehe
Naxis2k1
grade A whiteboy
Naxis2k1
Phoenix
Naxis2k1
