I just installed a bx1600d hifonics amp with 2 aw1006T audiobahn subs. the problem I am facing is that I dont know how to eq the amp. Here are the following options:
Subsonic: allows control from 15hz to 35hz
Bass EQ: allows control from 0db to 8db
Low Pass: allows control from 35hz to 250hz
Phase: shift allows 0 degrees to 180 degrees
Level: allows you to match the amplifier input level(gain) to the radio/cd output level.
The amp is 3000 watts max and 1800 watts rms. The subs are 1800 watts max and 900 watts rms. I have the two subs bridged down to 1 ohm each. (I have both positive wires from each sub going into 1 jack on the amp and both negative wires from each sub going into 1 jack on the amp.
Can someone explain to me what these do and what I should roughly set them at? I have a 5volt preout on my deck.
I have an 4 gauge amp kit with a 60 amp fuse. Is this enough?
Thanks for the help!
