quick ? about caps
bogiejoe1
vlx inside nuf said
ok guys i no caps are about worthless but i got a very nice one from my old school days that has a volt meter readout on it so im going to go ahead and wire it up but my ? is
since ive used this cap in the past then let it set for 3 years now is their anything i need to do before i reinstall it thanks for your time guys
joe
ya you need a diode to charge it. try a local audio shop they will prolly have extras. run it inline with your positive wire, between the wire and the cap. the cap should start showing a display around 8 volts, and when it hits 12 your good to hook up
You mean resistor.
I never used a resistor when charging mine, and was just careful hooking it up... disconnected everything, wired it in parallel, just like an amp. Then reset my circuit breaker and it was fine. I don't use one now, though.
You use a resistor to avoid the inevitable sparks that will be caused by trying to charge the cap normally.
You can also use a spare 12v lightbulb from a car, one of the small 1" ones. It'll slowly charge this way as well.
Learned this before I knew caps were dumb, especially ones witout the digital readout. Don't even look good.
bogiejoe1
vlx inside nuf said
bogiejoe1
delaware,ohio
bogiejoe1
