i bought a Solo baric 15 L5 from a friend and i have it hooked up to a pinoneer 760 watt amp..... works fine dual channeled.... but once i one channel it my amp overheats and cuts out..... anyone know a fix?
amp that will run the load you are trying to hook to it. If it is d2 you can wire te sub series for a 4 ohm load or parallel for 1 ohm load. If d4 you can parallel for 2 ohm.
