Quad voice coil
by that logic, a dual voice coil isnt really needed..a svc is a lot easier to wire, though a dvc isnt hard..
its not just more wiring options..you can run more power...strap a pair of amps to each coil..8 amps instead of just 4.
qvc's kinda confuse me. Seems like way too much work. I know memphis sells a Q1. could you in theory put that down to .5ohm or would it be .25? They really really confuse me.
I'll stick to my DVC's and call it a day.
It has nothing to do with being able to run more power...
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
so being able to run 2x as much power is a disadvantage?
depends //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Just because you are able to run more power doesnt mean the sub will take it. Given two versions of the same sub, one being a DVC and one being a QVC, they will both have the same power handling. The coil is the same size. As I said before just more wiring options.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
the quad coil was made available for the same reason as the dvc..so people could run more power to a single sub. has everything to do with running more power, being able to wire them in more configurations is simply an upside..
Audiopulse88
Audiopulse88
Portland, Mi
Safe_Cracker
