Speaker/Driver Selection
Sometimes, a speaker is designed or engineered for a specific enclosure. On the other hand, a majority of woofers can be used in various enclosure types.
As a rule of thumb, use the following equation to determine the suitability of your speaker.
Suitability factor = fs / Qes
Factor less than 50 the driver is best suited for a sealed enclosure
Factor between 50 and 100 the driver can be used for both sealed and vented enclosures
Factor above 100 the driver is best suited for a vented enclosure.
Use these factors as an estimation. For example if you want to build a sealed enclosure and the factor of the speaker is 55, the speaker should do fine in a sealed enclosure. The speaker suitability value is in the vicinity of the sealed factor.
The speaker being used has a Suitability factor of 55 which meets the criteria for a sealed enclosure.
This was determined by the following calculation:
Suitability factor = fs/Qes = 27/0.49 = 55
