Proto Pm7 Paintball Gun CP, Dye, Ect.+extras
Boomboy
Team D.O.A
ok, i need this stuff to go right away, i am looking for 999.99+shipping, i will not go any lower so dont ask...thanx
2007 Proto PM7 Blue/Black(color not being produced anymore so its kinda rare)
proto 4+3 pack with 4 pods 2007
500 reballs(they are real ones not the fake crappy ones) 2007
CP 68/45 tank with 4-5 years left on a 5 year hydro, i bought it fresh from CP on 3/07 date on tank is 2/07
XXL Proto Jersey 2007
XL Proto gloves 2007
XXL Proto Pants 2007
14 size nike cleats 2007
Dye Invision i3 Mask Blue/Black 2007
5 black macro lines
small parts kit
gun stand
Dye Rhyno Tank Cover blue/black 2007
Empire B2 with 9volt mod 2007
extra brand new 9volt mod
dye headband black 2007
extra brnad new dye headband 2007
3 battle swabs 2007 one with hole drilled in the top and an empire lanyard
extra brand new empire lanyard
NXE Gearbag 2007
NXE Backpack 2007
ALL stock things the gun, mask, bags, ect came with including manuals and original boxes.
EVERYTHING HAS ONLY BEEN USED 6 times except for the bags which have been used 2 times.
i am selling all of this for this price b/c i have insurrance and college to pay for...everything equals out to around 3750...
specs on stuff
GUN
New programming with 3 firing modes
The M7 also comes standard with all new metal eye plates
A new clamp neck knob
Low pressure bolt kit
A new improved LPR
Metal logo inserts
And a two piece barrel.
The trigger placement is 3/8" shorter, giving you more control by positioning your finger for optimal strength and speed on the trigger.
Additionally, the M7 is 1/5" shorter and 3.5 oz lighter than the M6.
Goggle Features:
The Forward Tab Retention System (FTRS) securely locks the lens into the frame under the most severe impacts.
The only lens-goggle system that is low profile, with no extruded edges.
Utilizing open and closed cell foam technology, specifically designed foam to sheet sweat and moisture away from your face.
The DYE Invision venting design is revolutionary to standard venting systems. The Invision Multi-Directional Venting System will throw your voice farther and clearer. The tested and proven patent pending venting configuration will make communicating with your teammates effortless, as if there were no vocal obstructions.
Dye Invision goggle systems come standard with extended ear protection.
tank
It’s here!!! The air system you’ve been waiting for. The CP Air combines everything you’ve been looking for in an air system and puts it together in one ultra light package. Super High Flow Rate, Fast Recharge rate, Superior reliability and on top of everything it’s rebuildable. All of this in a design that is nearly ½lb lighter than the competition. What more could you look for in an air system? The CP Air Combines it all and then backs it with the commitment to be at every PSP and NPPL to offer full factory support when you need it most. We took the same reliable technology that you have come to know and trust from the CP In-Line Regulator and created the ultimate bottle regulator. Patent Pending
68ci 4500psi - 2.63lbs
Reg Only - .29lbs
68/4500psi 11" overall
pants
The 2007 Proto Pant is built to perform, built to look good and built to last. Adjustable waist with Velcro closures makes a perfect fit every time, while the inner leg venting will keep you cool under fire. The lightweight design allows you to be comfortable, while the super-strong construction will hold up to aggressive play. Reinforced padded knee panels give protection against knee impacts and vented cargo pockets allow you to carry what you need. The combination zipper and button crotch panel is padded and helps protect what’s important. The sublimated paneling on the sides keeps bright and clean after washing. Leg piping and microinjection logos finish this pant off with a cool look and great style
jersey
The new 2007 Proto Jersey features a patent pending silicone injection chest/shoulder pattern that improves aim stability and prevents bottle slippage.
The V-neck collar and slim line ribbed cuffs provide comfort and stretch durability.
Underarm and side torso venting for optimal air flow during play.
Padded elbows help protect elbow joints and brightly colored sublimation keeps you looking stylish under fire.
Constructed with an oversized extra-long torso for freedom of movement and comfort.
Nylon overlock stitched seams hold up to abuse from rigorous play.
Nylon overlock stitched seams hold up to abuse from rigorous play..
gloves
Proto Glove 07 Increase your grip and comfort with the all new 07 Proto Gloves. They offer superior comfort and flexibility with enhanced form and control. Full Clarino palm, Airprene main body and Lycra finger gussets offer extreme ventilation. PVC impregnated grip on the palm helps improve grip. Compression formed knuckles with direct injection for comfort and style.
backpack
The NXe Elevation Series "Ventura" Backpack is an all-in-one solution for traveling to and from the field, as well as all over the world. With a re-designed, super comfortable vented-mesh back panel and a 3-tier storage system with custom designed marker storage, the 2007 Ventura is the perfect choice for a player of any level.
Features:
Custom designed marker storage panel with Velcro straps to secure marker, air tank, and other attached hardware.
Newly designed three-tier storage system for customized organization of gear
Padded laptop compartment with neoprene protective sleeve provides superior protection
Micro-fiber audio compartment with newly designed rubber logo headset pass-through
Ultra padded, vented mesh back panel provides maximum comfort
Four-point adjustable, padded shoulder straps allow customizable fit
Large main pocket with elastic sleeves to hold barrels up to 16"
Specialized pockets for Allen keys, O-rings and other tools.
Specially selected materials for maximum durability and ultimate style
2800 cubic inches of storage capacity.
executive nxe bag
3 heavy duty ATW (all terrain wheels)
Custom goggle storage compartment
Custom gun storage
Big Mouth design for easy access and quick in & out storage
Heavy duty retractable handle
NXe signature black nickel zipper pulls and specially selected elevation nylon for maximum durability and ultimate style
Pod Bag for easy pod storage
Dirty Shoe Bag, protects your gear from your shoes.
Specifically Designed Pockets for, tools, fully assembled marker or clean clothes.
Reinforced sides for maximum gear protection and bag stability
hopper
The world's fastest loader takes it up a notch. Not one to rest on success, the minds behind Empire's Reloader B introduce the next generation of ultra-fast loader technology: the Empire B2.
•Features:
•Built in adjustable sound sensitivity allows you to harmonize the B2 with the sound signature of your marker.
•Six selectable motor speeds and spring tension monitoring prevent ball breakage even with the most breakable shells
•Well balanced shape
•Increased ball capacity
•Polycarbonate diamond body construction
•Reinforced feed neck
•Soft-touch micro power switch
•Adjustable sound activation sensitivity
•Spring driven, true force-feed system
•Built in RIP drive system
pack
Completely designed from the ground up by paintball professionals that want a clean and simple solution to all pod problems. From this, the Proto Harness was born. Anatomically correct back padding system allows for a completely uninhibited range of motion, while still providing the level of comfort every player is dying to have in a harness. Designed to be worn around your waist to provide you with extra back support. Elastic straps to help release our pods into your open hand. No detail is missing. New for 2006--Micro-mesh venting in the back panel and vented elastic to keep the heat off when the pressure is on. A more aggressive Velcro pattern and wider positioning ensure a non-slip fit
pics
looks like a great package for an amazing price, if i had an extra grand laying around i would get this right now
good luck on the sale though
thank you
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Boomboy
Team D.O.A
Boomboy
Wisconsin
Boomboy
