Pro 60 problems
MIN_Roadkill
I have the Boston Acoustics pro 60 6.5 set and I noticed a couple problems while redoing the interior of my bronco. The driver door mid has the copper coil seperating and coming out the front of the speaker. Suggestion?
The other problem is not something I noticed but something I did. I took out the tweets so I could paint my doors and the grill came off and then I managed to put a small hole in the dome and put several dents in it. Is it fixable or do I need to start looking for replacement tweeters? If I need replacements, what would work with the pro 60 set?
how old are they, and were they bought from an authorized dealer? if the voice coil is coming out of the cone, i'd say you have some serious issues, but they may be able to be warranteed. the tweeter, you're probably outta luck there, unless you get lucky and they give you an entire new set to warranty the f'd up woofer.
I don't have any warranty, I bought them online:*******:
What mids and tweets would get as loud and be as clear or better than the pro 60 set ? I would like to hook them into the pro60 crossovers if possible, and keep the budget to around $200.
MIN_Roadkill
MIN_Roadkill
Oak Hill, W.V.
MIN_Roadkill
