Pristine DD M1A FS
ace_800
Its a M1C not a M1A
Pristine, was installed for about 1 year but the guy was deployed for 7 months so it only got about 5 months of occasional use. It wasn't a daily driver. Marks are only on the mounting holes and barely a scratch there. Might have the box with manual and warranty.
Was purchased from an authorized dealer and install by a professional shop.
DD website description:
The M1 enters the "c" version, our most popular amp in its 4th generation. The M1 is the cornerstone for most subwoofer applications, delivering over 1200 Watts of true RMS power at 12 Volts. The M1c delivers over 1700 Watts of continuous power at alternator charging levels and capable of 2500 Watts of dynamic power. We have compacted the new layout and when combined with the LV type twin power supply, have reduced the width by over 2 inches and the height by half an inch. The smaller size allows a plethora of mounting options. 4 Gauge power connections and through bolted RCAs are provided.
Input Sensitivity 8V - 0.2V
Variable High Pass Filter
Variable Low Pass Filter 20Hz - 200Hz
Variable Sub-sonic Filter 10Hz - 50Hz
Variable Bass Boost
Tested Voltage 11.8
Tested THD ≥1%
Damping Factor
Signal to Noise >100dB
Channels
Cont Power at 1 ohm 1200W x 1 ch
Cont Power at 2 ohm 780W x 1ch
Cont Power at 4 ohm
Bridged
Dynamic Power 2500 x 1
Efficiency thru Output 80%
Dimensions - mm 350mm L x 175mm W x 51mm H
Dimensions - inches 13.8 L x 6.89 W x 2 H
Shipping Weight 11 lbs, 5 kg
MSRP $589
250obo
included
ace_800
ace_800
Okinawa, Japan
ace_800
