215.00 shipped to the cont. usa
I have a old school ppi promos 425 4 channel amp that needs to sold ......
it is 1/2 ohm stable and puts out gobs of power and sounds awsome doing it...
the amp works 100% . the paint on the fins looks faded , but the art on the top is looking great......it not a mint condion amp , but if you need to push a couple pairs of mids and tweeters, or if you need to run some subs, this amp will do both and have you speaker begging for mercy....//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
this amp has the factory seal on the bottom of the amp....never been repaired...i will send a copy of the manual along with the amp....and it will come with the speaker plugs,,,
specs:
Output Power at 12V: (get alot more power at 14 volts)
4 x 25W @ 4 ohms
4 x 50W @ 2 ohms
4 x 100W @ 1 ohm
4 x 200W @ ½ ohm
2 x 200W @ 2 ohms
2 x 400W @ 1 ohm
specs:
4 x 25W @ 4 ohms
4 x 50W @ 2 ohms
4 x 100W @ 1 ohm
4 x 200W @ ½ ohm
2 x 200W @ 2 ohms
2 x 400W @ 1 ohm
