Precision Power PDX10K
NIB
RMS @ 2Ω, 16V 3,700W
RMS @ 1Ω, 16V 6,100W
RMS @ .5Ω, 16V 10,000W
If you know what this is you should already know this is not the kind of amplifier you can run with a stock alternator and the Big 3. 1,200 amps of current draw potential here.
$899.99 each
2 available and more can be special ordered
Send me your ZIP.
NIB
- Non-Regulated MOSFET PWM Power Supply
- All "N" Channel TO218 MOSFET Transistors
- Dual Internally Bridged Mono-blocks
- Ideal for 16V Applications
- Three-Way Protection Circuitry
- Dash Mount Remote Gain Control
- Dual 0 ga. Power Inputs, 4 ga. Speaker Outputs
- Harmonic Distortion 1.00%
- Frequency Response 15-250Hz
- Signal-to-Noise Ratio 87dB
- Damping Factor > 1000 @ 100Hz
- Signal Voltage 200mV-7.6V
- Potential Current Draw > 1200A
- Low Pass Filter 24dB; 35-250Hz
- Bass Boost 0-18dB; 40-120Hz
- Subsonic Filter 24dB; 15-50Hz
- Remote Gain Control Yes
- Dimensions 2.75"h x 12.625"w x 23.25L
$899.99 each
Send me your ZIP.
