Sold Precision Power PCX Competition Class Amplifier REDUCED! $250 shipped
BassmentJack
Resident Douchebag
$250 shipped and insured in the original box. This amp is a beauty!!!
Precision Power PCX Competion Class Amplifier. THIS AMP IS IN ABSOLUTELT MINT CONDITION AND HAS NO BLEMISHES NOR HAS IT EVER BEEN OPENED. This is the ultimate in SQ amplifiers.
Power Bandwidth 10 Hz - 50 kHz
Total Harmonic Distortion
S/N Ratio >115dB
Input Topology Instrumentation
Input Sensitivity 150mv - 12 Volts RMS
Input Impedance 10k Ohms
Load Impedance (stereo) 2 - 8 Ohms
Load Impedance (bridged) 4 - 8 Ohms
Supply Voltage 11 - 15 Volts
Damping Factor >500
Slew Rate >50 V/μS
QBASS PLUS™ Up To +18dB Boost
@ 30, 36, 44, or 60Hz
Crossovers 12dB/Octave
Crossover Frequency 30-4kHz
Idle Current: PCX 2125 1.5 Amps
NEW! Advanced Instrumentation Input Stage.
NEW! 12dB/Octave; HP/LP/FULL; 30-4kHz Crossover.
NEW! Independent Line Output Crossover HP/LP/FULL30-4kHz.
Fully Regulated PWM Power Supply. (2200,2400)
Triple Darlington Output Stage.
AM-V Protection Circuitry. (2200,2400)
AP-IV Protection Circuitry. (2125)
Forced Air Thermal Management.
QBASS Plus™ Bass Boost.
High Voltage Input Capability with -12dB Attenuation Switch.
Gold Plated RCAInput and Output Connectors.
PowerLock™ Speaker and Power Wire Connectors.
Mixed Mono/Stereo Operation, Bridged Mono
3-Yr Warranty
MODEL 4ohm STEREO 2ohm STEREO 4ohm MONO
PCX 2125 2 X 125 2 X 250 1 X 500
**ALL POWER RATINGS SHOWN ARE TESTED @ 12V; 20-20kHz
I have the PCX 4125 they are good amps...I;ve been trying to sell mine with the optional Q bass remotee for a little bit more than yours on here with no luck //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif Hopefully someone will buy yours...its hard to find amps with this clean of specs these days....
BassmentJack
Resident Douchebag
BassmentJack
USA
Louisiana_CRX
