Precision Power PC2400.2
bigguy2010
SQ
736
MI
Adaptive MOSFET Switching Power Supply
Fully Complementary Triple Darlington Output Stage
AM IV Protection Circuitry
QBASS PLUS™ Bass Boost
QBASS REMOTE™ Compatible
Advanced Buss Technology
Forced Air Thermal Management
Two-Way 24dB/Octave Linkwitz-Riley 90Hz Crossover
Crossover Line Outputs
Balanced Differential Input Stage
High Voltage Input Capability with Input Attenuation Switch
Gold Plated RCA Input and Output Connectors
PowerLock Speaker and Power Wire Connectors
Mixed Mono/Stereo Operation
Three Year Warranty when installed by an Authorized PrecisionPower Dealer
Completely Designed and Handcrafted in the USA
Specifications:
Power Bandwidth 4.5 Hz - 100 kHz
Total Harmonic Distortion 0.02 %
Input Topology Differential
Input Sensitivity 150mv - 12 volts RMS
Input Impedance 10 k Ohms
Load Impedance (stereo) 2 - 8 Ohms
Load Impedance (bridged) 4 - 8 Ohms
Supply Voltage 11 - 15 volts
Damping Factor >500
Slew Rate >50 V/mS
QBASS PLUS™ Up To +18dB Boost
Frequency Centers 30Hz, 36Hz, 44Hz and 60Hz
Idle Current: PC2400 1.5 Amps
Crossover Two Way, 24dB/Octave Linkwitz-Riley
Crossover Frequency 90Hz
Continuous Output Power Dimensions
PC2400
100 WRMS x 2 @ 4 ohm per channel
200 WRMS x 2 @ 2 ohm per channel
400 WRMS x 1 @ 4 ohm bridged
Length - 15.75"
Height - 2.25"
Width - 8.9"
Used - working 10/10, cosmetic 7/10.
150 Shipped CONUS ONLY - OBO
Included
bigguy2010
SQ
bigguy2010
MI
bigguy2010
