Precision Power BK1800.1D
  • 2
trumpet
Barry Schanz
New
2013 Closeout
ONLY 1 AMP AT THIS PRICE
Power Ratings:
  • RMS Power 4 Ohms(14.4V) 700W x 1
  • RMS Power 2 Ohms(14.4V) 1,100W x 1
  • RMS Power 1 Ohms (14.4V) 1,800W x 1
Additional Technical Specifications:
  • Full SMT Surface Mount Technology Circuitry
  • Double Sided Composite Epoxy PCB
  • 1-Ohm Stable Class D Monoblock
  • Variable 12dB 45Hz Bass Boost
  • Variable 0-180° Phase Control (1 ch.)
  • Dash Mounted Remote Gain Control
  • Three-Way Protection Circuitry
  • Delayed On/Off Circuit
  • Variable 12dB Low & Subsonic Crossovers
  • Direct Wire Power & Speaker Terminals
  • Wire Concealing End Caps
Dimensions:
8.25″ W x 19.75″ L x 2″ H
~$200 shipped
Precision Power BK1800.1D | Easy Way Electronics
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
437
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
343
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
SlugButter
    May 4, 2024
slater
    May 2, 2024
