Precision Power 356cs 6.5" Component set
06gtmike
6-1/2" 2-way Component System
Power Handling:
Peak: 240 watts per set / 120 watts each side
RMS: 120 watts per set / 60 watts each side
Kevlar, mica, fiberglass interlaced cone woofer
Silk dome tweeter
Phase plug for controlled interaction between mid and high frequencies
Woven tinsel leads
4 ohms impedance
Copper clad aluminum voice coil
Custom Crossover
12 dB High pass configuration
6 dB Low pass
+3 dB Tweeter level adjustments
180º Tweeter phase adjustments
Multi stage tweeter protection
Bi-ampable mid/mid-bass Zobel circuit
Top-mount depth: 2-1/2"
Comes in the original box and everything works 100%. Includes just about everything that came with them new minus some of the speaker wire. The mids do have a little deadener residue on them and one of the crossovers has a small crack on one of the terminal and 2 of the metal tabs inside the terminal broke off (Picture included and none of this affects anything).
$140 Shipped. No trades at the moment
Included
06gtmike
06gtmike
Williamsburg, VA
06gtmike
