Alright... my dad told me that soundstream has always been a great Amplifier company... i've been more into the Power Precision Comp series amps... but i came across a couple of Soundstream amps that have pretty much the same exact specs but at a better price.... check it out
Precision Power PCX-2400 2-Channel Amplifier $700+ @ acaraudio.com
Stereo, 4 Ohms: 2 x 400 Watts
Stereo, 2 Ohms: 2 x 800 Watts
Bridged, 4 Ohms: 1 x 1600 Watts
S/N Ratio: >115dB
THD: 0.02%
Input sensitivity: 0.15-12V
Damping: >500
Crossover Frequency: 30Hz-4KHz
Crossover Slope: 12dB/Octave
Crossover Design: Two-Way
Cooling Fan
QBass: QBASS™Plus
Dimensions (inches):2.375 x 10 x 30.25"
VS.
Soundstream REF1600.2 $569.00 @ Onlinecarstereo.com
Output RMS @ 4Ohm: 2 x 480W
Output RMS @ 2Ohm: 2 x 800W
RMS bridged @ 4Ohm: 1 x 1600W
T.H.D:
Signal to noise ratio: > 115dB
Damping factor: > 500
Frequency response: 10-70 kHz
Input sensitivity: 0.15-12.0
Crossover slpoe: 18dB
Crossover frequency: 30Hz -4 kHz
Dimensions: 10" x 2.5" x 19"
RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
Trident™ amplifier protection topology
Ultra-Low ESR Capacitance Bank ensures rapid power delivery for dynamic peaks
Hawkins Bass Control™ Proprietary bass equalization topology
IDI™ (Intelligent Distress Indicator) Gives visual indication of amplifier protection status
Harmonic Bass Alignment™ Produces tighter and more accurate bass
Fully regulated MOSFET power supply
Triple Darlington output circuitry
BIP™ Bias input protection
Rail stabilization protection circuitry
Bi-linear selectable 2-way crossovers for amplifier and line outputs
Continuosly variable high and low pass crossovers
Balanced line inputs for the highest level of noise rejection
Gold RCA inputs and outputs
Gold 2-gauge power connector
Tri-mode operation
What do you think??
S/N Ratio: >115dB
THD: 0.02%
Damping: >500
Cooling Fan
QBass: QBASS™Plus
VS.
T.H.D:
Tri-mode operation
What do you think??
