Sold PPI art ax606.2, Xtant X603, IDQ12...
ivanfbi
I have quite a few things for sale, basically the whole system. I am planning to redo everything, try something new. I have
PPI ART series ax606.2, 6 ch amp, one of the best PPI has ever created. 10/10 condition, looks practically new, collectors piece.
$550 shipped to CONUS
6 Channel Amplifier
Output Power at 11 to 15V:
6 x 50W @ 4 ohm
6 x 100W @ 2 ohm
2 x 200W @ 1 ohm (rear 2 channels)
3 x 200W @ 4 ohm bridged
1 x 400W @ 2 ohm bridged (rear 2 channels)
Fuse: 80A
Dimensions: 24" x 9.25" x 2" (61cm x 23.5cm x 5.1cm)
Weight: 14 lb. (6.3 kg.)
Manufactured in 1996
Next up is Xtant X603 3/5 channel xtant's X-series amps, the ones that cost over a grand, when were new. so very rare, unique and underrated. it's about 7.5-8/10 works perfectly, but has a couple of scratches, chrome is very hard to keep clean
$300 shipped CONUS
3 channel amplifier
2 x 75W + 1 x 150W at 4 ohms
2 x 150W + 1 x 300W at 2 ohms
1 x 300W bridge at 4 ohms
Fuse: External 100A
Next I have JL XR650-csi speakers minus the tweeters, plus SSCS6 tweeters. in 9/10 condition. I sold the JL XR tweeters, cuz they were too bright, SSCS6 ones were perfect. crossovers look good, work good. XR crossovers can work active.
$175 shipped CONUS
Continuous Power Handling: 70W Continuous
Rec. Power Range (per channel): 25 - 150 Watts
System Efficiency: 89.5 dB @ 1W/1m
System Nominal Impedance: 4 ohms
System Frequency Response: 48 Hz - 25 KHz ± 3 dB
Also, Image Dynamics IDQ12V2D4 i believe, don't remember if it's V2 or V3. 9/10 condition
$150 shipped
Nominal Impedance (IMP) 2 / 8 ohm
* DC Resistance (Re) 1.75 / 7.0 ohms
* Resonant Frequency (Fs) 19.7Hz
* Electrical "Q" (Qes) .276
* Mechanical "Q" (Qms) 4.4
* Total "Q" (Qts) .259
* Equivalent Volume (Vas) 5.82 ft3
* One Way Linear (Xmax) 13.7 mm
* Cone Area (Sd) 530 cm2
* Sensitivity (Spl) 89.9 db
* RMS Power Handling (Pwr) 100 to 500
* Speaker Displacement .07 ft3
I know these pictures are not mine, I will take pictures today and put the here. Reference is ebay name dondokov, plus I believe I already dealed here with tdawg30, jiggy2dmax, maybe somebody else, i don't remember. Feel free to ask questions, willing to negotiate on the prices a little bit.
Wiiling to trade for IDMAX 12 or well anything I might be interested in, let me know
Replaced the pictures, don't have the speakers at home, will update
Call me at 425 seven seven three 24 seven four
or e-mail me at ivanfbi at yahoo dot com
BTW, check ebay, there is one PPI exactly like mine going for over $600 right now. It cannot theoretically be in better condition than mine, because mine is practically new. so please don't lowball me.
I powered them with PG x100.2 and it sounds really really good, they can take up to 150-160W RMS, so anywhere between 60-150 will be good.
The amp has rear speakers connections, and I have read that they are passive, which means that they are images of the front channels. I haven't got much info on that, but i know it works
ivanfbi
ivanfbi
Seattle WA
ivanfbi
