Item(s) for Sale
owerbass XA-1500D Xtreme Series 1500 WATT RMS @ 1 Ohm Mono Class D Car Amplifier
Item(s) Description/Condition:Used with marks but works 100% no bass knob. POWERBASS XA-1500D
The XA-1500D is an XA series class D mono amplifier which features remote bass control, allowing you to fine tune your amps’ special BASS EQ circuitry right from your dash.
The heavy duty 4-guage, CNC machined high efficiency power and ground Inputs enable maximum power transfer for an uninterrupted performance. The Sub sonic filter offers maximum system flexibility, while the 4-way Self-diagnostic protection circuitry, guards against short circuit/thermal overheating or impedance overload. You can strap two amps together in a Master/Slave configuration to function as one for superior power output of up to 2500 watts. Features:
RMS Power: 500W x 1 @ 4 ohm
RMS Power: 1000W x 1 @ 2 ohm
RMS Power: 1500W x 1 @ 1 ohm
Strapped Power: 2500W
Free Bass Remote Included!
Oversized Power and Ground Outputs - 4 Gauge CNC machined high effeiciency connection for max power transfer
4-Way Protection Circuitry
Total Harmonic Distortion:
Frequency Response: 10Hz - 400Hz
S/N Ratio: >90 dB/W/M
Damping Factor: >200
Input Sensitivity: 0.3 - 8.0 volts
Crossover Slope: 24 dB
Crossover is fully adjustable from 40 - 500 HZ + there is an additional subsonic filter
High-Pass Crossover Freq: 50Hz - 250Hz
Variable Subwoofer EQ: 0/+18 dB
Subwoofer EQ Frequency: 45Hz
Fuse Rating: 120A (3x40A fuses)
Dimensions:
14.17" x 10.51" x 2.56"
360mm x 267mm x 65mm
Price:$150 OBO
Shipping and Miscellaneous Item Information:Free
Dimensions:
Price:$150 OBO
