power to boston pro 60's
theres your problem, the crossover is not gonna highpass the woofer:fyi:
it will lowpass at around 3-4k i think it was, you need to set a highpass x'over to around 60-80hz depending on how your setup is, components are NOT meant to play bass, midbass yes, deep bass no...
I have a HPF on the mid, 150 hz. Any lower and they'll bottom out fairly easily. I've never ran them hard and just listened to them bottom out over and over. 80 is still way too low for mine for some reason. Doors are fully deadened/sealed.
yea, i had to leave mine up high like 150-180, i got a 3sixty.2 now and its set at 100hz but at 24db slope, so it works alot better
dont matter because im about to change out to a set of hertz mlk2's sans the x'over and run active, needs to hurry up and get to the store so i can do some glassing
JLBAMA
JLBAMA
decatur, al
bamaboy
