Power Surge Batteries
looks like good stuff, i am interested
The 3000's are flat out insane- 8D case- 300AH- 6000 amp watts and 4000cca //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Looks like generic batteries from batterymart.com with an ugly label slapped on them.
LOL ok ryno //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Do an IR test on those batts u got, then tell me whats up //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
GREAT, the same chinese battery with a new label.
Btw, those CA, AH etc specs don't mean shit since they are not rated by BCI standards.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif wow- built in FL- but chinese batts? - Cases are cases, its whats inside kiddo //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Have you tested one already?
Call Jim @ power surge if you have any tech spec ?'s - 352-400-6677 or Brandon @ 615-509-0803
30% larger cells than Kinetiks, XS's, Dekas, etc..
Hmm... 30% larger cells?
Power Surge 1250
Size – 12.91” x 6.77” x 8.58”
Weight – 67.24 lb
Amp Hour – 125
Amp Watts – 2400
Kinetik HC2400
Size - 13"x6.7"x8.5"
Weight: 69lb
Amp Hour: 128
Amp Watts: 2400
So.... its not 30% larger, if fact its nearly an exact match! What a coincidence that the Power Surge is so similar to a Kinetik (also Chinese) battery!
I wouldn't care if this company is just adding to the competition, but trying to trash other brands is not a good move for a new company.
Power Surge 1250
Weight – 67.24 lb
Amp Hour – 125
Amp Watts – 2400
Kinetik HC2400
Weight: 69lb
Amp Hour: 128
Amp Watts: 2400
How is that trashing other brands?
oh wait, i just saw ur avatar lol now i know the kinda person im dealing w/
Cells are inside the battery, but LARGER than the cells in other batts- wow your a douche bro
Let me break it down for ya
Kinetik uses Top Cycle Cells in their batteries- this forces the electrons to move upwards from the bottom to the top of the cells - then to the posts- where the current is bring drawn- along with reg electrolyte inside the batt.
Power Surge uses Full Cycle Cells in their batts- which ARE 30% bigger than the kinetiks- These cells allows the posts to draw from the full length of the cells in the batteries, making it more efficient with less IR.. Along with a more potent electrolyte = better battery..
buh bye
I bet it cost a ton to use AC/DC songs for marketing. I would figure with 30% larger plates than everyone else that it would mean a lot more lead meaning it would weigh 20-30% more than the others too not less.
Do you mean Internal Resistance? Or am I confusing the terminology with something else? To me it could mean Impulse Response, Insulation Resistance....etc.
Also, please explain to me how you are supposed to have more plate, and larger cells, while having the same volume. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif This is not saying you're wrong, but I must be missing something.
Just called and got some quick pricing on a few batteries that are of common interest.. And all of these prices are for a short time after the 4th of July, but only go up about $15 after the sale ends... The 600 is $224, the 750 is $256, and the 1000 is $288.. These seem like pretty fair prices compared to other batteries that put out the same AH, but these also seem like they'd hold up longer with the better acid and bigger cells..
S.B.C.
S.B.C.
IL
ngsm13
