Digital Switching Power Supplies are more efficient because you don’t lose as much signal or gain distortion because of induction and capacitance in the huge windings of the transformers. This means that when the current need spikes the power supply can react faster, depending on the cyclic rate of the switching. Also, from experience with the CX1202 and other “70 Volt” Line amps, which usually need a lot of raw electrical power when running on bridged mono 140V driving line level equipment, the CX1202 with the Digital Switching Power Supply doesn’t “grunt” under a heavy load if the current levels are unavailable when the amp needs them. This efficiency with the power is great because believe it or not when you tell a promoter that you need 2x 120 Volt 50 Amp circuits you sometimes get an orange extension cord ran 50 ft from a source that’s hovering about 109 and only 20 amps (extreme situation that did happen, and with some foot to *** we did get decent enough power to work with aka a generator). But the same efficiency pays off in SQ and general reliability.
