Sold Power Acoustik, JVC, Phoenix Gold/Audiosource, Jensen, etc.
drumman8524
I have had all this sitting in our garage and need to get rid of it.
Legacy LVS26T 6.5 TFT LCD Sunvisor Monitors (BNIB) $199 Shipped
# TFT Color Monitor
# Resolution: 1,200 (H) x 234 (V)
# Viewing Angle: Left/Right: 45, Top: 30, Down: 30
# System: NTSC
# Display component: Colour LCD
# Remote Control
# Back-lit source: High-brightness cathode flourescent tube
# Power supply: + 12V
# Power Consumption: 8W
# Size: 15" x 6" x 0.827"
Power Acoustik FX-15W Subwoofer 1000 Watt RMS (BNIB) $129 Shipped . This has been sitting in my garage i bought it to use but ended
up not using it.
# 280 oz. magnet
# 3" BASV voice coil
# SPL 94dB
# Fs: 28 Hz
# Vas: 3.42 cu.ft.
# Qms: 4.71, Qes: 0.49, Qts: 0.44
# Xmax: 12.5mm
# Sealed box: 2 cu..ft.
# Ported box: 3.5 cu..ft.
# Tuning: 38 Hz.
# Port size: 6" (dia) x 11" (Length)
# No. of ports: 1
# Mounting Depth: 9.5"
# Dual 4 ohm voice coils
# Die-cast aluminum basket
# Candy blue finish with diamond Cut
# Kevlar Laminated cone
# High-F magnet cover
# High roll santoprene surround
# Woven tensile leads through spider
# Black poly-cotton spider
# Black anodized voice coil former
# 1 piece rubber gasket
# Metal-flake royal blue finish with diamond cut
# Chrome push terminals
JVC KV-PX9B EXAD 3.5 in. Screen 20GB Mobile Navigation GPS Receiver (BNIB) $140 Shipped
FEATURES:
# JVC KV-PX9 Exad Eavinu KVPX9B mobile gps navigation device in black is a compact, portable GPS system for the car that combines GPS navigation with audio/video playback and data storage.
# The JVC KV-PX9 packs multiple functions into an efficiently-sized device.
# 3.5-inch TFT screen.
# Internal 20GB hard disk drive.
# Access navigational information, play music and view movies and images.
# Part of JVC EXAD line, JVC KV PX9 Eavinu features the most advanced technologies and design concepts.
# JVC KV-PX9 dedicates 13GB of hard disc space to navigation maps and over 13 million points of interest (P.O.I).
# The remaining 7GB are available to store movies up to 40 hours, music files up to 1400 songs and pictures up to 4500 files, plus data.
# Files are easily transferred using the USB 2.0 input or SD card slot, SD cards purchased separately.
# Compatible file formats are WMA, MP3, WMV, ASF, AVI (320 x 240 maximum) and JPEG.
# The JVC KV-PX9 3.5-inch full-color screen is a low reflection, high luminance display for easy visibility under a wide range of lighting conditions.
# Touch-screen controls make for simple operation, as does a voice guidance system that offers a choice of three languages and a male or female voice.
# Two map views are offered: 2D - an aerial view, or 3D - a through-the-windshield view.
# The on-screen display includes current location street name and distance to next turning point.
# Touch-screen controls include day/night adjustment, brightness, zoom in/out and map scroll.
# Other features include destination memory and multiple route/re-route calculation options.
# The P.O.I. screen displays nearby restaurants, car rental locations, gas stations, hotels, parking and more.
# For audio playback, JVC KV-PX9 includes a pair of built-in stereo speakers.
# Sound can be routed to the line input of a vehicle head unit.
# An RF modulator can be used to route the sound through the vehicle FM tuner.
# JVC KV PX9 includes a headphone jack.
# Features JVC exclusive CC Converter that enhances the sound quality of compressed music files.
# The JVC KV-PX9 is especially suited to mobile applications thanks to shock absorbing gel supports that cushion the hard drive.
# An acceleration sensor detects when the unit is dropped and automatically pulls the pickup away from the hard drive to protect it.
SPECIFICATIONS:
# Designation: Automobile
# Form Factor: Fix
# Map capabilities: Internal
# User interface: Touch Screen
# Display Size: 3.5 in.
# Special Features: Waypoint Icons
# Audible Features: Voice Navigation Instructions
# Trip calculator : Route Recalculation
# Grids: Lat/Lon
# PC Interface : USB 2.0
# Built in memory: 7000 MB
# Expension slot type: SD (Secure Digital) Card Slot
# Antenna External: Antenna Hookup
# Battery Type and Quantity Proprietary:Li-Ion
# Battery Life: Up to 3 Hours
# Width: 3.6 in.
# Depth: 1.8 in.
# Height: 3.4 in.
Power Acoustik FUBR-15 15" 2000 Watts. Used but in good condition $60 dollars + shipping
* 2000 watts power handling
* 200 oz. magnet
* 2.5" ASV Voice Coil
* SPL 93 dB
* Tuning: 34 Hz
* Port size: 4" x 6.75"
* Number of ports: 1
* Dual 2 ohms voice coil
* Die cast aluminum
* Black wrinkle finish with Diamond cut
* None-pressed paper cone
* Wrinkle finish front & back plate
* Large foam rubber surround
* 1-piece EVA gasket
* Black spider
* Woven tinsel lead through spider
* Chrome screw terminals
Phoenix Gold AUDIOSOURCE AMP 5.1A MONO AMPLIFIER AMP5.1 AMP (BNIB Refurbished Model) $99 Shipped
1 x XLR Audio In - Rear
1 x RCA Audio In - Rear
1 x RCA Audio Out - Rear
1 x Banana Receptacle Speaker Terminal - Rear
1 x Headphone - Front
1 x AC Out
Dimensions:2.75" Height x 5.5" Width x 11.8" Depth
Output Power:1 x 100W RMS @ 4Ohm 0.1% THD
1 x 75W RMS @ 8Ohm 0.1% THD
Additional Information:Steel Enclosure Material
Mono Sound Output Mode
Overload protection
Cooling fan
Frequency Response:20Hz to 20kHz
Brand Name:phoenix Gold
Weight :9 lb
Impedance:4Ohm to 8Ohm
Signal to Noise Ratio (SNR):95dB
Also i have an old school jensen amplifier that i am trying to get rid of from 1998 $65 Shipped
http://www.caraudio.com/forum/showthread.php?t=431501&highlight=jensen+1998
great prices on the PA subs
thanks, yeah im just trying to get rid of them...The FUBR-15 i had in my car for a little bit but it still works perfect...The only reason i never used the Power Acoustik FX-15W is i decided to keep my amp that i had so i couldn't use it so it has just been sitting in the garage.
You can't really find the FX-15W anywhere & i dont know of anyone who owned one, i guess Power Acoustik didn't make that many of them.
drumman8524
drumman8524
Mooresville, NC
drumman8524
