Power Acoustik Bamf5500/1d Bamf
it should do atleast 3,000 rms with good electrical.maybe if your lucky 3,200rms....some members in here have one of these amps..there good bugget amps
the 4000watt peak will do 2000 rms..the 5000 watt peak will do near 3000rms...i member in caco told me about this
I've heard that it is the same board that was in the older PA3000db amp. If that's the case...it's also the same board that was in the Kole Audio Q1-3000d. That being said, the PA BAMF 5500 and the Kole Audio KX1-5500 probably use the same exact board. Both will only do 2300wrms @ 1 ohm. The Kole Audio amp is $219 while the PA BAMF is $279. Buy the Kole Audio.
with 200amps of fusing, no it wont do 3200w, 2000 if you are lucky
BAMF5500/1D
5500W
1700W x 1CH
2500W x 1CH
3200W x 1CH
0.2%
(-3dB)
20Hz-200Hz
40Hz~200Hz
20Hz~50Hz
0dB ~ 18dB
0.2V~6V
10k Ohms
40A x 5
16.92" x
8.26" x 2.16"
SPECIFICATIONS
I am confused.
If you know so much about this amp and then comparing it to Kole, which you are right, then why ask about the amp in question. Shit makes no sense to me.
Sounds like you want the Kole. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I am confused.
x2!..if money is the issue just save up a lil and get a decent amp that would put out real 3,200wrms...i would say crunch GP3000..good bugget amp
I am confused.
sorry guys, that was a C/P that i found from another forum, i seen the thread was movin with people giving input, so i pasted that!!,,,, I dont know jack about that amp
tweet02
tweet02
miami, fl
quest51210
