dave sz
So, it's a 70RMSx4@4ohms, meaning the voltage coming out of the amp when setting up the gains should be below 16.74v, right? Well, when I do that, the rear speakers, Kicker ssmb6 6.5" free air midbass speakers, get kind of distorted. The fronts are fine but the tweeters are a bit unclear, MB QUART DSE 216. The crossovers that came with teh comonents have a 0db, -3db, -6db option for the tweets, should I use the -3 or -6db options to make them less noticeable? When I set up my gains I used a 1000hz track for the components, and a 50hz, 80hz, 120hz, 150hz for the rear midbass speakers. I put a hpf on the compnents, around ~120hz, and a lpf of 100hz for the kickers, 30-500hz range on those. I'm not sure what frequency tone I should've used for the midbass rears, so I tried all the ones mentioned above, what do you guys suggest I use? Should I just set the gains at around 16v and see if that works, or is it something else wrong? I have a 2/0ga cable running through a fuse block to the amp as power, then I have a 2/0ga,
