The only difference is the heatsink which PA's tech support says is better on the Kole and the Kole amps are tested more with tighter tolerances. That is why the Koles are a tad more $$$.the kole have a pretty sweet look to them. And yes they are the exact same amps.
If you beleive PA's tech support, the amp heirarchy at PA goes:so its kole over PA?
sorry to tell you but the koles are actually cheaper.The only difference is the heatsink which PA's tech support says is better on the Kole and the Kole amps are tested more with tighter tolerances. That is why the Koles are a tad more $$$.
I stand corrected.sorry to tell you but the koles are actually cheaper.
At least to dealers //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
no problem man.I stand corrected.
