Sold Power Acoustik A3000DB 2000+RMS @1ohm - $200 + Shipping
wccoug21
Amp has been rebuilt. All power and output transistors have been replaced along with driver transistors and the large capacitors.
Amp has been thoroughly tested for an hour plus to be sure its good to go and it is and runs flawlessly. Couple scratches but overall in great condition i'd give it a 9/10 also comes with bass remote
Price is firm. If it doesn't sell I will most likely keep it and sell my amp that I use. Pics below
# 1 Channel
# 1100 Watts @ 4 Ohms RMS
# 1800 Watts @ 2 Ohms RMS
# 2300 Watts @ 1 Ohm RMS
# 3000 Maximum Power
# Hi Speed Digital Circuitry
# Fully Regulated PWM Power Supply
# Four Way Protection Circuit
# 1 Ohm Stable Stereo
# Bridging Synchonization
# Variable Low Pass 50Hz-150Hz
# Variable Subsonic Filter 15Hz-40hz
# Variable EQ @ 45Hz
# Phase Switch 0-180
# Remote Dash Mount Low Level Gain Control with Cable
# Frequency Response: 15Hz to 150hz
# S/N Ratio: 100db
# THD: 0.5%
# System Distress Indicator
# Inputs Sensativity: 200mv-8v
# Dual Mono Speaker Output Connectors
# Gold Plated Heavy Duty Power & Speaker Terminals
# Dimensions: 16.8" x 11" x 2.3"
wccoug21
wccoug21
Bay area, ca
wccoug21
