Pot brownies
i learned you don't just throw it into the mix, its actually harder then i thought.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif, I bet that tasted excellent //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Does the pot have to be cooked to get you high? I was thinking of just mixing some ine with some pudding, but not sure if it would work.
So basically, if you ate a fat bud by itself, would it get you high? Or only if its cooked?
Is it a stronger buzz, weaker, what?
Does the pot have to be cooked to get you high? I was thinking of just mixing some ine with some pudding, but not sure if it would work.So basically, if you ate a fat bud by itself, would it get you high? Or only if its cooked?
Put the pot in something you can heat up(the butter for brownies), you can extract the thc at a certain temp and then you strain it to get all the buds out. At too high of temp I believe you can destroy the thc. I've only seen it done though, that's what hippies are for //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.... Never had to eat your stash //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif no if you simply eat it, I think you pretty much just flushed some money down the drain //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif.
So it has to be heated to get high from it? I was just gonna break up some buds and put them in some pudding or lasagna or something
Again, say you have a fat bud sitting in front of you, you just pulled it out of your bag. If you eat it, will it get you high?
And if you make pot brownies does it stink up the house like weed?
Different buzz or what?
For sure cook it. Much more of the active intoxicants are relased when its cooked. Our digestive tracks just arent made to process and release such harsh plant matter..a lot of the good stuff just goes right through you if you dont cook it.
Try running it through a coffee grinder and then simmering it in butter for 20-30 minutes. Then strain out the plant matter, toss it and just use the butter for brownies or hell even on some toast.
There are also some ways to boil it in butter and water then let it all cool.. butter seperates out and leaves the water and plant matter at the bottom, but its more of a pain to get just right.
Of coures i dont condone this horrible behavior.
And yes cooking it will make your house smell very strong.. but not like when its burning.. unless you know the smell you might not recognize it for what it actually is.
**** hippies...
Brownies are nasty period..
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Very true, when made right (strong enough) they make me gag. That horribly greasy taste...eh makes me feel a little ill just thinking about it.
So it has to be heated to get high from it? I was just gonna break up some buds and put them in some pudding or lasagna or somethingAgain, say you have a fat bud sitting in front of you, you just pulled it out of your bag. If you eat it, will it get you high?
I guess but ya might as well smoke the nug or vap it. Simply taking a nug from you stash and sticking it in your mouth... I wouldnt do it //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif. Waste if ya ask me. I have had Hippie brownies made properly and pizza with pot sprinkled on... was way different(and as for the taste of the pizza with bud sprinkled on.... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif . //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif.... as for smell I wouldnt do it if someone was gonna be home within a few hours.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
EDIT: //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif why all the hating on brownies?
zachzchw
zachzchw
ohio
Savstyle
