ports
spike_e
ballin on a budget
i have a box plan for my 3 12w6's. the subs will be on the top of the box firing into the glass of my integra. the ports will also be on top of the bow. there will be 3 3" ports.
is it good to have round ports vs a slot port?
also would anyone be willing to look at the plan and make sure they are gonna work?
Flared ports are very good at virtually eliminating port noise. Port noise is the noise created by the friction of air moving through the port. If you have sharp edges on a port (as with standard round ports, which we do not use), you are going to have significantly more port noise than with a flared port. A flared port requires the smallest acceptable port area for a subwoofer box. Since the ends are flared, and the inside of the port is round (no sharp edges), it is unlikely you will be able to notice any port noise from the subwoofer enclosure. However, if you are running a large, high-powered subwoofer, you will want to use two flared ports. A single flared port is still capable of creating port noise when very large amounts of air pass through it.
With a slot port, you can use as much port area as needed for your application, which is especially helpful in SPL applications. A slot port requires more port area than a flared port to minimize port noise. We generally use a rule of 12 square inches of port area per cubic foot of internal volume of the custom sub box. You may go with a larger port area, but this will increase the total volume and length of the port. In turn, a large port area will mean an increase in the total size of your subwoofer box. Slot ports are the standard for our ported custom subwoofer boxes.
http://www.klausaudio.com/articles/c/subwoofer-box-help/flared-ports-vs.-slot-ports.cfm
spike_e
ballin on a budget
spike_e
prattville AL
wesl56
