ports instead of fans
bryce-man
im thinking about cooling my amp by setting it about 6 inches parallel from the side of the box and having my port push/pull the air on/off the amp
im using 3 ports and only goin to put one on the side with the amp.
the other two:straight under my seat,
pointing to the pasengers side of my extended cab
is that good enough for cooling an amp
Win ISD sais that the speed of the air outof the ports is 28.5 m/s (93 f/s) (64 mph)
thanks
IIRC, anything over 17m/s is audible as port noise....someone correct me if I'm wrong //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
thats what i heard somewhere.. but in another place i heard 110 f/s wich is 33.5 m/s.. so idk
ill just put it down to below 17 and go from there
.. is that still good enough for cooling the amp
p.s. where i heard it was 17 m/s they said it was 17 at 100 watts
that 28.5 was at rms(900)
its at 9.5 at 100 wats
but yeah im sure that where i found it it said 17 m/s at 100 watts
right now theres 3 4inch ports at 13.5 inches long for tuning at 35.1... and i dont know if i wanna do 4 but if i have to i will
Probably wouldn't be hard, same concept as liquid cooling a CPU.
Except with a lot more bouncing around in a car. I don't know if I'd trust putting water + electronics in a car environment. I don't care how tight those connections are, it doesnt sound good to me.
yea bazooka had a whole "chil" system as they called it. It went thru both the amps and the subwoofers to liquid cool them. Didnt really catch on, i never tried it but was skeptical. They said the cooling "doubled the subs power handling"
bryce-man
bryce-man
beach cities CA
bryce-man
