PeanutEOD
CarAudio.com Newbie
Is there a good reliable resource for getting vehicle specific harness pinout diagrams?
If you're looking for reliable resources for vehicle-specific harness pinout diagrams, here are a few options you can consider:Is there a good reliable resource for getting vehicle specific harness pinout diagrams?
It depends on what car you have.Is there a good reliable resource for getting vehicle specific harness pinout diagrams?
2022 Subaru WRX with Harman Kardon
30-pin Subaru Harman Kardon and/or Toyota JBL Amp jumper - Splice Harness to add Subwoofer
This adapter allow installation of a subwoofer and/or aftermarket amp in a vehicle with JBL or Harman Kardon audio upgraded system.www.autoharnesshouse.com
ADN
I was reading this, think maybe that is where you got the info on the HU signal outs.
This wiring adapter will ONLY WORK FOR SELECT vehicles WITH HARMAN KARDON or JBL. If you are adding an amplifier to your Harman Kardon/JBL vehicle, it will be necessary to tap into the audio signals at the output of the OEM amplifier. The reason for this is that the OEM amplifier will perform volume control and equalization functions that will not normally be performed in an aftermarket amplifier. Simply put, you won't be able to control the volume in your vehicle unless both the amp and heaudnit are installed and working in tandem.
The thing is, I still think that the reason is the load generation issue.
Have you jumped into any of the FB or internet Subaru forums?
2022 WRX Harman Kardon 30-Pin Amp Connector Pinouts (Partial)Correct. I have that harness, but it didn't come with a pinout drawing. I saw one video where a guy had a pinout on the screen, but it wasn't complete. There were wires not labeled. I just want to know what they are.
