PG Octane R 5.0:4| 4 chan into a 3 chan?
CMichaelT
My question is can i use the front outputs to run my 6.5 type R comps, and use the rear outputs bridged to run an 8 or 10 inch sub? If that is possible then my next question is there any sub you can reccomend? I'm not looking for monstrous bass just something that will sound clear.
Here are the stats of the amp for continous power:
50x4 @ 4 ohms stereo
75x4 @ 2 ohms stereo
125x2 @ 4 ohms bridged
If it makes any difference my car is 300ZX, that's why i'm opting for no rear speakers since from what i've read they aren't 100% necessary, but that coems down to a matter of opinions. If i do use rear speakers i'll keep the stock ones i suppose.
oki dokie good deal then i'll look into those two, any place you'd recommend to get them?
i'm looking for clarity more than anything with a deeper sound. also i was planning on putting them in a custom sealed enclosure, any recommendation for how much cu volume for the sub in feet³?
umm... I doubt the PG is going to handle the 1 ohm bridged..... or even two. Shouldn't he get the d4? Then he has options for 4 ohm bridged and two ohm...
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
If he gets the d4 ohm model he can either run it 2 or 8 ohms. D2 he can run it 1 or 4. When I told him to get the d2 did you actually think I ment for him to run it at 1 ohm:crazy:
Okae so what it looks like i'll be doing is Using the amp to power the Alpine Type-R 6.5 Comps up front. Then i'll use the Rear ouputs to run the sub at 4 ohms wired in series. The setting for the amp should be High Pass in front and Low Pass in Rear. Also what gauge wire should i be running to power the amp? Then from the amp: to the Comp's? to the Sub? and any place you would recommend purchasing these things or can i just ebay it?
^Does everthing sound right? //content.invisioncic.com/y282845/emoticons/goodorbad.gif.fe1f80382c74d93547176ee10a15b645.gif
CMichaelT
CMichaelT
Silverdale
Towncar
