Sold PG Cyclones............cleand internally, realigned, new bearings where needed.
reallyxxxxloud
Hi just a bit of background history on me. I'm really****loud on Talkaudio and have been there for many years. I'm reallyxxxxxxloud on PG Phorum and my ebay is really******loud with 100% + feedback.
I've three PG Cyclones for sale. But own 7 in total... (have owned 9 of these over the years...).
There's two at 8 ohms and one rarer 4 ohm version... The 4 ohm version has some sort of circuit board under the end cap that has three large dominate caps on it? I have seen this before but those to were 4 ohm versions someone else had... If anyone has seen or knows what this is please enlighten us.
The 8 ohm versions will be sold at $800.00 Australian Dollars with free basic shipping. If you require insurance you may pay the difference.
The 4 ohm version I'm wanting $1000.00 Australian Dollars with free basic shipping.
USD converted as of today's date 17/08/2010 is $715.00 and $890.00.
They will come in there boxes and foam packing...
Now there are a lot of myths about these subs.... So listen to none.
Noise will be present if.
1: if they have worn bearings
2: if they are full of magnetic dust
3: if they are not aligned properly
4: if they are rubbing in the vane
5: if you tune it way to high
There is slight motor noise with a good properly set up Cyclone but it is minimal.
I'm using two Cyclones in my Mitsi GTO with two Eclipse Titanium 10"s. Its enough to make you feel sick. If you have an upset stomach you will definitely be needing to go afterwards.
I have seen comments about these being a novelty based on there's not much music recorded in that range... BS. I listen to a very wide range of music. Classical, Rap/Crunk, Dubstep are just three off the top of my head that play the low notes...
Also having a good infrasonic set up reinforces your subsonics and so forth. Try turning off your sub and listen to your music then turn it back on- notice how much more alive it sounds (a crude example but you get the idea)...
Sold this one last week locally. It had a small crack in the plexi and vanes were glued by some dickhead :roll: I had two that were glued but now have sold both.
Sorry the last 4 were taken with my Iphone at night....
whitedragon55 1 Had sent Him a pm ages ago when i first signed on here... But haven't heard a reply back...
eL_wEEnIe not rich niqqa.... Just no ho //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
reallyxxxxloud
reallyxxxxloud
Australia
reallyxxxxloud
