People with Soundline SLC's
aren't these speakers rated at 150watt max?? wouldn't something go wrong if pushing too much power?
You'll never see full rated power from an amplifier with music, the signal dictates the power the speaker sees. However the bigger the amplifier's capability, it ensures effortless performance during dynamic peaks- so extra, clean power is always welcome. By clean, I mean power made easily before clipping.
That being said that rated 60 watts you feed your SLC's only comes at a clipped level(distortion) so you are actually seeing less. An increase in power will definitely show you performance gains in the most inefficient part of the set, the midbass.
They most def dont need alot of power to sing and sound good, but the midbass kick really comes alive with power to spare.
You'll never see full rated power from an amplifier with music, the signal dictates the power the speaker sees. However the bigger the amplifier's capability, it ensures effortless performance during dynamic peaks- so extra, clean power is always welcome. By clean, I mean power made easily before clipping.That being said that rated 60 watts you feed your SLC's only comes at a clipped level(distortion) so you are actually seeing less. An increase in power will definitely show you performance gains in the most inefficient part of the set, the midbass.
interesting...I have heard this but never put it to practical use. Manny I need a suggestion: my amp does 60x4 for my germs...I planned on using the DMM and getting voltage of 15.4v at like volume 45 (3/4). however, for the tweeters i planned on giving them around 40ish watts per the dmm method. Now I know a 1khz tone gain setting tutorial is supposed to be safe, but I planned on giving the mids the full rated power and the tweets less...this way high passed at 80 these babies can really sing. can the mids handle the full "15.4" gain setting that I do at volume 45 on music? or should I do what I originally planned on which was to set it at 15.4v at volume 45 and never play the radio higher than like 41-42. I mention this because between volume 42 and 45 there is a significant increase in voltage when I did some preliminary testing with the DMM sorry for the thread hijack. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Quite honestly theres no reason to 'protect' those tweeters. I've fed the older, non-chambered Cal25's actively 100watt chs to themselves. I say hook it up and let it rip. If you go under Rainbow's website under the Germs and you look into each drivers technical datas you'll see it dont quite match up to the 'set's power requirements. The tweeter by itself has a 100 watt nominal/150 peak power rating;)
No minimum power requirement noted- typical of tweeters as they dont need much power.
The mid, however asks for 75rms minimum, 100rms nominal and 150 rms peak.
http://car.rainbow-audio.de/products/technical.php?lan=2&pro=1&lin=17
Obviously you dont have to go watt per watt as per requirement, but it gives you an idea looking at the raw driver specs whay you got to play with. So with that said, it should be no surprise if someone sent 200-300rms per side amp channels to the Germs and be in serious business:naughty:
Do you have a way to level match via the HU? That is more important IMO.
3.5spdmax, where would be that "power to spare"? 125? 100? 85?
I'd feel more comfy in the ~100 and over range- at that point its loud enough and strong enough to satisfy most for passive use.
If you notice under the specs for the woofer alone it states a minimum 50rms, 100rms nominal, 150 peak as well. These are quality speakers my friend, they can take power.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
http://car.rainbow-audio.de/products/technical.php?lan=2&pro=1&lin=7
I think I understand. I'm still new to the audio field. You're saying lets say for instance my speaker's (alpine type-r) is RMS is 55watts then it's ok to put the gain of my phoenix gold 800.4 amp all the way up? The amp is rated at 125watt @ 4ohm per channel so with the gain all the way up for one channel would be 125watts correct? Thus I'm pushing 125 watts(with gain all the way up) to a 55watt rms speaker is ok? thank you for the knowledge.
btw, i'm about to put passve crossovers rated at 300hz on the alpine type-r 6x9's is this recommended?
no
Guess you got all questions answered here already huh Manny. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Always one friggin step ahead of me. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Quite honestly theres no reason to 'protect' those tweeters. I've fed the older, non-chambered Cal25's actively 100watt chs to themselves. I say hook it up and let it rip. If you go under Rainbow's website under the Germs and you look into each drivers technical datas you'll see it dont quite match up to the 'set's power requirements. The tweeter by itself has a 100 watt nominal/150 peak power rating;)No minimum power requirement noted- typical of tweeters as they dont need much power.
thanks Manny I guess I turned soft because I've had alot of noob user error setting up the set. I'm going to tune them via the dmm to full power and let them rip. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I have been reading the Rainbow site and noticed the disparity between driver ratings. what do you mean by level matching? I have the pioneer 6600 TV setup which is basically the same as the 05 pioneer radio's tuning wise.
The gain on your amplifier is not a volume control. Its to level match the amp with the output of your HU. Once you set the gains correctly, yes you should have a decent usable range on that power up to where your HU tops off voltagewise.
Even so, you need to understand the concept of music- its filtered by your xovers and delivered to your speakers in series of pulses- up and down signals ,rarely in a continuous manner such as playing a sine wave. If you can follow that concept , you can realize how people send an inconceivable amount excess power to their speakers systems with no problems, and enjoy the benefits of dynamic headroom.
By no means, does this mean you should overpower a speaker beyond its thermal limits. Become familiar with the speakers capabilities and use common sense.
I wouldnt put 300hz passive on 6x9's. The whole purpose of using 6x9's by those that do it for more sound and more midbass. Midbass freqs are roughly in say the ~80-220 hz range for example.
Are you going active or biamping? If you are biamping, the xover has some control of how the drivers are level matched as opposed to just the amps gains. At that point you can have a good old time with the phase relationship controls on that fancy xover:naughty:
bi amping...each speaker gets its own channel. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif would you recommend leaving the crossover frequencies at 2200, or change them both to 2600? I know it is a matter of preference but to be honest I don't know what instruments would be afffected by this and how it would effect the overall sound. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Unfortunatly, the only answer is to try yourself and listen for it. With drivers off axis, in our cars in factory location (mid in doors, tweets in apillars) I've found I rather have freq underlap between midrange and tweets-it makes for smoother transition and takes some midrange peakiness out- most cars boost the 1k-4k area dramatically and results in harshness. So I woud likely set the mid at 2200 and tweet on the 2600 side. But its trial an error, at least you have those options without going active.
that was exactly what I was going to try..you also have a pm sir. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok i got it. time to play around with it.
PESteele
I wang on an 8 in a van
PESteele
annapolis
KaPPaBaLL
