C CrispedUp 10+ year member CarAudio.com Veteran 4,425 12 The Jungle Apr 3, 2009 #1 well i just added a new template, but now when i go to my site, all it says is "restricted access". now, what could be the problem? Click to read more...
OP C CrispedUp 10+ year member CarAudio.com Veteran 4,425 12 The Jungle Apr 3, 2009 Thread Starter #3 link to said site? Click to expand... http://www.viprei.com
A AVSTANG02 Banned 4,173 7 Las Vegas Apr 3, 2009 #4 Try this http://forum.joomla.org/viewtopic.php?t=158748
MikeofTulsa Moderator The one and Only! 26,789 182 Tulsa, OK Apr 4, 2009 #5 so you installed the template and then on the admin side of things choose that template correct?
OP C CrispedUp 10+ year member CarAudio.com Veteran 4,425 12 The Jungle Apr 4, 2009 Thread Starter #6 so you installed the template and then on the admin side of things choose that template correct? Click to expand... yes. then when i went to preview the site, it said restricted access.
MikeofTulsa Moderator The one and Only! 26,789 182 Tulsa, OK Apr 4, 2009 #7 can you switch back to the other template?
OP C CrispedUp 10+ year member CarAudio.com Veteran 4,425 12 The Jungle Apr 4, 2009 Thread Starter #8 can you switch back to the other template? Click to expand... yeah. looks like the problem is within the new template, since the site works fine with the old one.
MikeofTulsa Moderator The one and Only! 26,789 182 Tulsa, OK Apr 4, 2009 #9 did you make sure it was compatible with your version of joomla?
