Pavtube Blu-ray Video Converter Ultimate
423youin
5
USa
Pavtube Blu-ray Video Converter Ultimate is a comprehensive powerful application designed for people who want to rip and convert Blu-ray movies, general DVDs, and different sorts of video files into lots of other media formats according to their end use. That is to say this software is a combination of a Blu-ray ripper, a DVD ripper and a video converter. As long as you possessed it, I dare to say that you are able to dealing with nearly all the video and DVD collections on hand without any troubles, since besides supporting Blu-ray disks and common DVDs, it also supports inputting a wide range of media formats, including camcorder footage in the format of M2TS, MTS, TOD, MOD and more, other video files in the format of MP4, 3GP, AVI, MPG, MPEG-4, MKV, TS, ASF, MOV, MKV, etc., namely, both HD videos and SD files are all compatible with this software. In that way, it is no longer a tough work for you to handle whatever video files you have.
How to use Pavtube Blu-ray Video Converter Ultimate?
1. Click “Add Video” to import video files, or click “Load DVD” to load Blu-ray disks or DVDs.
2. Set format and destination folder for the output files.
Click the drop-down list of “Format” to choose a format as output format, and click the folder icon at the end of “Output” to specify a save path.
3. Click “Settings” button to adjust audio and video parameters like bit rate, frame rate, sample rate, etc.
4. Click “Convert” button to start DVD ripping or video converting.
Additionally, Pavtube Blu-ray Video Converter Ultimate allows user joining multiple files into a single file, even the files from Blu-rays, general DVDs, or the separately imported video files can be combined together. What you should do is just ticking the checkbox of “Merge into one file”. Moreover, you can also use it as a simple video editor, because it provides several kinds of editing functions, including “Crop”, “Trim”, “Text Watermark”, “Image/Video Watermark”, “Effect”, and “Audio Replace”, with these functions, you can remove unwanted area of the videos, or select a specific duration to convert, or add watermarks, or realize special video effects, or take place of the original audio with your preferred ones.
According to many users’ feedbacks, Pavtube Blu-ray Video Converter Ultimate highlights that it adopts advanced audio-video sync technology, which can absolutely let video and audio match very well without problems, and as a matter of fact, such is the case. What a beautiful utility, are you aroused in interest?
Generally,most of the DVD to iPhone Converters accomplish the same tasks to convert DVD to iPhone for playing the DVD movie on your iPhone, but what is a good DVD to iPhone Converter? The best converter in my mind is the one offers best output video quality and with high conversion efficiency saving my time. Leawo DVD to iPhone Converter meets the two standards after you have tried it. The output video is best in quality with synchronous video and audio and the conversion is fast thanks to its batch conversion to convert a list of files at a time.
The converter makes the DVD to iPhone conversion easy. Just with DVD import and export will start and finish the conversion job. Moreover, it can rip DVD to iPhone with selective Chapters, Titles and Video_TS, and join them together.
Let's see how this DVD to iPhone Converter transfers movies from DVD to iPhone:
Step 1
Insert the DVD disk into the DVD drive, open the program and import the DVD files.
Step 2
Do the settings:
1. In Subtitle, select the subtitle language.
2. In Audio, select the language of the audio.
3. In Profile, select iPhone Moive.
4. In Output, set your destination folder for the output file.
Step 3
Click "Customize" to customize the video in your desire. (The functions under the "Customize" item are only available in Pro version!)
a. Effect adjustment:
Drag the slides for Brightness, Contrast, and Volume to improve the video quality.
b. Drag the buttons on the slide to trim the video or change the values directly in the Start Time and End Time.
c. Choose a selection from "Letter Box" to crop the video, or directly drag the dot frame for it. Click "OK" to confirm the settings.
Step 4
Click the big button to start the conversion.
dvd ripper | dvd to 3gp | dvd to apple tv | dvd to avi | dvd to flv | dvd to iphone | dvd to ipod | dvd to mp4 | dvd to psp | dvd to zune |
Pavtube Blu-ray Ripper is a powerful and dependent DVD and Blu-Ray DVD Buckup, Ripper and Converter which enables you directly to copy your DVDs or Blu-Ray DVDs on your hard disc for playing, to rip and convert your Blu-Ray DVD movies and general DVDs, even the protected DVDs and Blu-Ray DVDs, into other popular audio and video formats like AVI, ASF, MPEG, MP4, WMV, MKV, MOV, FLV, SWF, RM, 3GP, AAC, AC3, MP3, OGG, WAV, WMA, M4A, etc to playback on your beloved portable players such as iPod, iPhone, Apple TV, Zune, Blackberry, PSP, Creative Zen, Xbox, etc. And you need not install AnyDVD any more.No matter you are a Windows user or a Mac user, just try about Pavtube, I am exactly sure it will not let you feel disappointed.
If you are a Mac user you can click here to download :
Thanks . Good luck !
423youin
423youin
USa
brinks315
