I have a brand new in box Orion HP 2800 amplifier for sale guys. 200 shipped is my price. Comes with 1 yr. warranty also.
Here are the specs...
Orion HP2800 Features
Orion industrial heatsink with illuminated logo
Mil-Spec double-sided circuit boards
Massive loosely-regulated MOSFET power supply
Patent-pending ESP port
Digitally programmed input voltage
Control over turn-on delay
Input sensitivity lock-out mode
Anti-theft and valet modes
On-board self diagnostics
Control, program, and read using the DEI BitWriter™ or PocketWriter™ (available separately)
Variable 50-500 Hz low-pass or high-pass crossover
INTELLiQ bass optimization
Variable 0-10 dB INTELLi-Bass equalization
Variable 20-150 Hz subsonic filter
Satin finish direct-wire power and ground connections
Optional HP-RB1 remote bass level control
Full CEA-2006 compliant specifications
HP2800 Specifications
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 125W x 2
THD at 4-Ohm RMS Power:
Bridged RMS Power @ 4 Ohms: 400W x 1
Speaker Level Inputs: yes
Preamp Outputs: no
Built-In Crossovers: HP/LP
Bass Boost: 0-10 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 77 dB
Fuse Rating: 2 x 30 amps
also, sorry that i cant play the waiting game on this, had 2 people ask to hold it, then flaked out on me, no more holding for people. Money talks, holding bs crap walks. 1st come first serve.
Also, this is here at my house, not the warehouse, so you will get tracking same day of purchase.
Thanks.
Preamp Outputs: no
Bass Boost: 0-10 dB
Thanks.
