Orion HCCA 275g vs. U.S AMPS AX1000X which is better?, amp comparison
rjcastr
To all you amp freaks out there
these are two of the best power driviing amps my vintage orion Hcca 275g is of course legendary line of Orion it can drive 1100 watts rms at 1 ohm stable the U.S amps Ax1000x can push 1000 watts rms at 1 ohm as well , they both for bass so im deciding which one would provide clean bass and is an overall better amp?
Any suggestions?
the orion is rated at 1200w @1ohm if you can suplpy it with a constant 14.4 you will see around 1500-1600w. the us amps will be without a doubt alot easier on the electrical system but will probaly only give you 1300w. i doubt u'd hear the difference so in this case us amps
ftw
rjcastr
rjcastr
los angeles
BassAddictJ
