Onkyo sr506 7.1 surround sound receiver
jmkanek
1. Product:
2. Specs:
Product Specifications
Amplifier Section
Power Output - Front L/R 75 W + 75 W (8 ohms, 20 Hz-20 kHz,
0.08%, 2 channels driven, FTC)
100 W + 100 W (6 ohms, 1 kHz, 0.1%,
2 channels driven, FTC) Center 75 W (8 ohms, 20 Hz–20 kHz, 0.08%,
100 W (6 ohms, 1 kHz, 0.1%, 2 channels
driven, FTC) Surround L/R 75 W + 75 W (8 ohms, 20 Hz–20 kHz,
2 channels driven, FTC) Surround Back L/R 75 W + 75 W (8 ohms, 20 Hz–20 kHz,
2 channels driven, FTC) Dynamic Power 180 W (3 ohms, 1 ch)
160 W (4 ohms, 1 ch)
100 W (8 ohms, 1 ch) THD (Total Harmonic Distortion) 0.08% (Rated power) Damping Factor 60 (Front, 1 kHz, 8 ohms) Input Sensitivity and Impedance 200 mV/47 k-ohms (Line) Output Level and Impedance 200 mV/2.2 k-ohms (Rec out) Phono Overload - Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB Tone Control ±10 dB, 50 Hz (Bass)
±10 dB, 20 kHz (Treble) Signal-to-Noise Ratio 100 dB (Line, IHF-A) Speaker Impedance 6 ohms–16 ohms
Video Section
Input Sensitivity/Output Level and Impedance - Video 1 Vp-p/75 ohms (Component and S-Video Y)
0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
0.28 Vp-p/75 ohms (S-Video C)
1 Vp-p/75 ohms (Composite) Component Video Frequency Response 5 Hz–50 MHz, -3dB
Tuner Section
Tuning Frequency Range - FM 87.5 MHz–107.9 MHz AM 530 kHz–1,710 kHz FM/AM Preset Memory 40 stations
General
Power Supply AC 120 V, 60 Hz Power Consumption 4.9 A Dimensions (W x H x D) 17 1/8" x 5 7/8" x 14 15/16"
(435 x 149.6 x 379.2 mm) Weight 21.56 lbs. (9.8 kg)
Product Features
Amplifier
# Channels 7.1 Power (8ohms 20-20kHz 0.08%) /Ch 75W Power (8ohms 20-20kHz 0.05%) /Ch - THX Certified - Continuous 6ohms Rated Certified 4ohms performance - All Discrete Circuitry Dual PUSH-PULL Design - Independent Block Construction (Amp/Preprocessor) - Toroidal Transformer - Independent Power Supply - Bi-amp Capability For Front BTL Capability For Front -
Processing
DOLBY Decoder PLIIx, DD, DD-EX DTS Decoder DTS, ES, NEO6, 96/24 Dolby PLIIz - ONKYO GAME Surround Modes - DTS Surround Sensation Speaker / Headphone - Neural Surround - THX Processing Mode - Audyssey Dynamic EQ Audyssey Dynamic Volume - Direct/Pure Mode / - Music Optimizer 192K/24 Bit DACs VLSC - isf Certified Calibration Control -
Connectivity
Audio I/O 6 / 2 Phono Input - Digital Audio IN (OPT/COAX) 2 / 2 Digital Audio OUT (OPT/COAX) - Composite I/O 4 / 1 S-Video I/O 3 / 1 Component Video I/O 2 / 1 Front-Panel A/V L / R / V Front-Panel Optical - Front-Panel Portable input (stereo mini jack) - HDMI I/O 3 / 1 HDMI Version V1.3 Pass Through Component Video Upconversion - Multi-Channel Input 7.1 Analog Pre-Outs SUB Speaker A/+B - Powered Zone2 Zone 2 Line Out Zone 2 Video Out - Zone 3 Line Out - iPod Ready (DS-A2X) HD Radio Ready - XM Radio Ready - SIRIUS Radio Ready - Internet Radio Capable - Streaming Audio From PC - Streaming Audio From USB memory -
Integration Access
RS-232 - IR Input - Ethernet - ONKYO-RI System Control 12V Trigger -
Miscellaneous
Pre-Pro/Learning Remote / - Back-Lit Remote - On Screen Remote Programming - Bi-directional Remote Setup - Activity Based Remote - Color-Coded Speaker Terminals Auto Speaker Calibration W/Mic. (Audyssey 2EQ)
3. Description/Condition:
in great shape, works great.
its hdmi passthrough, which means you cant get audio from the hdmi cables, but has optical and coaxs audio inputs, it sounds great.
4. Price: :
asking 200 shipped obo.
5. Pictures:
Uploaded with ImageShack.us
jmkanek
jmkanek
Wise, VA
jmkanek
